作者 主题: B450M迫击炮内存无法超频  (阅读 377 次)
WD_Mantis
B450M迫击炮内存无法超频
« 于: 九月 15, 2021, 11:58:48 上午 »
配的是海盗船的内存,具体情况见下
主板BIOS是最新版本的。
试过开X-AMP和手动调内存,保存设置后开机始终是2133,求解,谢谢!
Manufacturer
Corsair
Series
Vengeance LPX
Part Number
CM4X8GD3000C16K4D
Serial Number
Undefined
JEDEC DIMM Label
8GB 1Rx8 PC4-2133P-UA0-10
Architecture
DDR4 SDRAM UDIMM
Speed Grade
DDR4-2133P downbin
Capacity
8 GB (8 components)
Organization
1024M x64 (1 rank)
Register Model
N/A
Manufacturing Date
Undefined
Manufacturing Location
Taiwan
Revision / Raw Card
0000h / A0 (8 layers)
[th]DRAM COMPONENTS[/th]
Manufacturer
Micron Technology
Part Number
D9TBH (MT40A1G8WE-083E:B)
Package
Standard Monolithic 78-ball FBGA
Die Density / Count
8 Gb B-die (Z01A / 20 nm) / 1 die
Composition
1024Mb x8 (64Mb x8 x 16 banks)
Input Clock Frequency
1067 MHz (0.938 ns)
Minimum Timing Delays
15-15-15-36-50
Read Latencies Supported
24T, 23T, 22T, 21T, 20T, 19T, 18T...
Supply Voltage
1.20 V
XMP Certified
1499 MHz / 16-20-20-38-58 / 1.35 V
XMP Extreme
Not programmed
SPD Revision
1.0 / January 2014
XMP Revision
2.0 / December 2013
Re: B450M迫击炮内存无法超频
« 回复 #1 于: 九月 15, 2021, 06:14:57 下午 »
如果同时接两支内存,可以试试单支内存,能否都开XMP 成功?
如有开GAME BOOST 或CPU超频,请先关闭后,再验证
