作者 主题: GT72 6QD-201XCN 更新BIOS修复intelME漏洞报错  (阅读 474 次)
fby001_wangdui
« 于: 一月 18, 2018, 05:30:14 下午 »
ME118H.bat运行日志如下:
Check internet access first, please wait.
Updating Intel ME driver part...
Done.
Updating Intel ME firmware part (for Normal CPU)...
Intel (R) Firmware Update Utility Version: 11.8.50.3425
Copyright (C) 2007 - 2017, Intel Corporation.  All rights reserved.
Communication Mode: MEI
Checking firmware parameters...
Warning: Do not exit the process or power off the machine before the firmware update process ends.
Sending the update image to FW for verification:  [   0 % ]
Sending the update image to FW for verification:  [   1 % ]
Sending the update image to FW for verification:  [   2 % ]
Sending the update image to FW for verification:  [   3 % ]
Sending the update image to FW for verification:  [   4 % ]
Sending the update image to FW for verification:  [   5 % ]
Sending the update image to FW for verification:  [   6 % ]
Sending the update image to FW for verification:  [   7 % ]
Sending the update image to FW for verification:  [   8 % ]
Sending the update image to FW for verification:  [   9 % ]
Sending the update image to FW for verification:  [  10 % ]
Sending the update image to FW for verification:  [  11 % ]
Sending the update image to FW for verification:  [  12 % ]
Sending the update image to FW for verification:  [  97 % ]
Sending the update image to FW for verification:  [  98 % ]
Sending the update image to FW for verification:  [  99 % ]
Sending the update image to FW for verification:  [ 100 % ]
Sending the update image to FW for verification:  [ COMPLETE ]
FW Update:  [  0 % ]
                       Do not Interrupt
                       Do not Interrupt
                       Do not Interrupt
FW Update:  [ 4% (/)]
FW Update:  [ 6% (-)]
FW Update:  [ 9% (\)]
FW Update:  [ 12% (|)]
FW Update:  [ 14% (/)]
FW Update:  [ 17% (-)]
FW Update:  [ 19% (\)]
FW Update:  [ 22% (|)]
FW Update:  [ 24% (/)]
FW Update:  [ 26% (-)]
FW Update:  [ 99% (-)]
FW Update:  [ 99% (\)]
FW Update:  [ 99% (|)]
FW Update:  [ 99% (/)]
FW Update:  [ 100% (/)]
Error 8703: PLEASE REBOOT YOUR SYSTEM. Firmware update cannot be initiated without a reboot.
!!! Please ignore the error message above. Your CPU is Ultra-low-voltage CPU.
Updating Intel ME firmware part [for Ultra-low-voltage CPU]...
Done.
自动重启后用intel工具扫描,显示已修复,但好像更新后休眠功能坏掉了,休眠了但启动后系统日志报错:
Windows 无法从休眠状态恢复,错误状态为 0xC0000411。
上一次系统的 12:49:50 在 ‎2018/‎1/‎18 上的关闭是意外的。
系统已在未先正常关机的情况下重新启动。如果系统停止响应、发生崩溃或意外断电,则可能会导致此错误。
Intel(R) Management and Security Application Local Management Service 服务在启动时挂起。
系统信息:
Product Name:                 GT72 6QD
OS:                           Microsoft Windows 10 企业版 64 位 Ver.1703(OS build 15063.0.amd64fre.rs2_release.170317-1834)
BIOS Version:                 E1782IMS.11D
BIOS Release Date:            2016/10/14
EC Version:                   1782EMS1.1091106201514:23:24
CPU:                          Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
Memory:                       8192 MB @ 1066 MHz
Graphics:                     NVIDIA GeForce GTX 970M, 3072 MB
VBIOS Version:                84.04.48.00.31,3145728
Network:                      Killer Wireless-n/a/ac 1535 Wireless Network Adapter
Network:                      Killer E2400 Gigabit Ethernet Controller
SHIFT mode:                   None
Power Plan:                   电源方案 GUID: 381b4222-f694-41f0-9685-ff5bb260df2e  (平衡)
Windows Hotfix
KB4022405        , Update               , 20170614
KB4048951        , Security Update      , 20171120
KB4049011        , Update               , 20171116
KB4048954        , Security Update      , 20171120
大师005
  • Sr. Member
Re: GT72 6QD-201XCN 更新BIOS修复intelME漏洞报错
« 回复 #1 于: 一月 22, 2018, 10:36:17 上午 »
休眠问题,确认一下NV显卡驱动的版本是哪个版本?
大脸猫Felix
« 回复 #2 于: 一月 23, 2018, 03:36:52 下午 »
官方的最新bios刷新两次后,再更新这个Me应该就可以了
fby001_wangdui
« 回复 #3 于: 一月 24, 2018, 09:36:33 上午 »
驱动程序日期:2018/1/3
驱动程序版本:23.21.13.9065
数字签名者:Microsoft Windows Hardware Compatibility Publisher
操作系统更新到了最新的windows 10 x64 1709,上面的驱动是windows10自动更新后的驱动,不是独立安装的版本。
今天发现,电源设置里面FN+F12设置为休眠,进入休眠状态后(指示灯全部熄灭,鼠标已停止供电状态,马上按电源键)按电源按钮启动后,可以正常恢复到休眠前的状态。但昨天下班后,合上电脑盖子(电源设置里面也是设置为了休眠),今天早上开机就无法恢复休眠前的状态了。报错信息和之前一样。
fby001_wangdui
« 回复 #4 于: 一月 24, 2018, 09:38:15 上午 »
这个很早就刷到了最新版本,所以应该不是bios的问题,确认这个Me的BIOS之前的版本都已经刷过了,之后才更新的这个Me版本的BIOS
大师005
  • Sr. Member
« 回复 #5 于: 一月 24, 2018, 06:55:22 下午 »
驱动程序日期:2018/1/3
今天再确认一次阖盖试看看,另外建议使用DDU方式移除NV显卡驱动后重新使用NV官网提供的版本进行安装
fby001_wangdui
« 回复 #6 于: 一月 25, 2018, 09:36:28 上午 »
驱动程序日期:2018/1/3
昨天把鼠标(S12-0400C40-AA3 )拔掉了,之后进入的休眠,今天早上启动后,可以正常恢复到之前的状态。
