作者 主题: GT72S 6QF 风暴英雄版本 BIOS刷成6QE,刷不回来了!!!  (阅读 1887 次)
tikoer
« 于: 八月 03, 2017, 08:09:15 上午 »
GT72S 6QF 风暴英雄版本 BIOS刷成6QE。本应该是MS-1783版本,结果刷成了MS-1782了。
现在刷不回MS-1783,UEFI BIOS升级提示Failed! Wrong image format 11。怎么解决?
现在还可以正常使用Windows 10, 只是GTX980显卡不能安装驱动。
Here is the info extracted from MSI help desk.
System Information
Serial Number:                FFFFFFFF
Product Name:                 GT72
OS:                           Microsoft Windows 10 Pro 64-bit Ver.1703(OS build 15063.0.amd64fre.rs2_release.170317-1834)
Windows Product Key:          3V66T
HDI Build:                    non-OEM
BIOS Version:                 E1782IMS.114
BIOS Release Date:            2016/01/28
EC Version:                   1782EMS1.1091106201514:23:24
CPU:                          Intel(R) Core(TM) i7-6820HK CPU @ 2.70GHz
Memory:                       16 GB @ 1066 MHz
                               - 8192 MB, DDR4-2133, SK Hynix HMA41GS6AFR8N-TF
Graphics:                     Microsoft Basic Display Adapter, 0 MB
VBIOS Version:                N/A
Drive:                        SSD, LITEON L8H-256V2G, 238.47 GB
Drive:                        HDD, USB FLASH DRIVE, 14.91 GB
Drive:                        HDD, HGST HTS721010A9E630, 931.51 GB
Network:                      Killer Wireless-n/a/ac 1535 Wireless Network Adapter
Network:                      Killer E2400 Gigabit Ethernet Controller
Network:                      Bluetooth Device (Personal Area Network)
SHIFT mode:                   None
Power Plan:                   Power Scheme GUID: 381b4222-f694-41f0-9685-ff5bb260df2e  (Balanced)
Programs and Features
SteelSeries Engine 3.10.9                                     , 3.10.9               ,
Synaptics Pointing Device Driver                              , 19.3.4.184           ,
SCM                                                           , 13.017.04187         , 20170729
Intel(R) Chipset Device Software                              , 10.1.1.14            , 20170729
MSI Remind Manager                                            , 1.0.1704.1901        , 20170728
Help Desk                                                     , 1.0.1706.1901        , 20170729
Dragon Gaming Center                                          , 2.0.1701.0601        , 20170728
Intel Extreme Tuning Utility                                  , 6.0.2.8              , 20170728
Intel XTU Library                                             , 10.015.08120         , 20170728
Intel(R) Processor Graphics                                   , 20.19.15.4404        ,
Realtek High Definition Audio Driver                          , 6.0.1.8117           ,
Microsoft OneDrive                                            , 17.3.6943.0625       ,
Microsoft Office Professional Plus 2016 - en-us               , 16.0.4266.1003       ,
Vulkan Run Time Libraries 1.0.3.1                             , 1.0.3.1              ,
WinRAR 5.40 (64-bit)                                          , 5.40.0               ,
Office 16 Click-to-Run Licensing Component                    , 16.0.4266.1003       , 20170728
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.21005 , 12.0.21005           , 20170729
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.21005    , 12.0.21005           , 20170729
Microsoft SQL Server Compact 3.5 SP2 x64 ENU                  , 3.5.8080.0           , 20170728
ACPI Driver Installer                                         , 2.1                  ,
foobar2000 v1.3.16                                            , 1.3.16               ,
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501  , 12.0.30501.0         ,
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.21005    , 12.0.21005           , 20170729
Java 8 Update 144                                             , 8.0.1440.1           , 20170728
Microsoft SQL Server Compact 3.5 SP2 ENU                      , 3.5.8080.0           , 20170728
Java Auto Updater                                             , 2.8.144.1            , 20170728
Office 16 Click-to-Run Extensibility Component                , 16.0.4266.1003       , 20170728
Office 16 Click-to-Run Localization Component                 , 16.0.4266.1003       , 20170728
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501  , 12.0.30501.0         ,
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.21005 , 12.0.21005           , 20170729
Windows Hotfix
KB4022405                                                     , Update               , 20170727
KB4025376                                                     , Security Update      , 20170727
KB4025342                                                     , Security Update      , 20170728
OS Activation
Name: Windows(R), Professional edition
Description: Windows(R) Operating System, RETAIL channel
Partial Product Key: 3V66T
License Status: LicensedHere is the info extracted from MSI help desk.
« 最后编辑时间: 八月 03, 2017, 05:04:05 下午 作者 tikoer »
Re: GT72S 6QF 风暴英雄版本 BIOS刷成6QE,刷不回来了!!!
« 回复 #1 于: 八月 03, 2017, 02:16:36 下午 »
有几个问题再与您理清楚:
1.GT72S 6QF的model name是MS-1783. GT72S 6QE的model name是MS-1782.
2.您电脑是GT72S 6QF,但是您将BIOS刷成了E1782IMS.114吗?
同时EC也更新了1782EMS1.109?
3.我们官网并没有摆放这两个版本的BIOS和EC,请问您是从哪里得到这两个版本的BIOS和EC的呢?
4.MSI所有的BIOS和EC都有防护机制,如果您电脑的市场名不一样,电脑会自动检测BIOS和EC,而且不会让我们使用者更新成功。
5,可否告知您电脑的条码,在机器的背面。我们会帮助您确认您电脑正确的市场名以及正确的BIOS和EC版本。
感谢!
tikoer
« 回复 #2 于: 八月 03, 2017, 05:00:21 下午 »
非常感谢您的回复!
首先这是我最近购买的二手机。由于D面没有任何条码和贴纸,因此,我没法查询此机的具体型号。我倒是在打开底部面板后,在内部组件上看到一些贴纸和型号标识,不知是否有价值。例如pcie卡是MS-17823,ver:0B。
不过我通过其配置和机器内部的硬件规格推断出,这一定是GT72S 6QF风暴英雄特别版。
我也不知道ms-1782的BIOS E1782IMS.114是如何刷进去的,我拿到机器时就是这样,而EC已经是MS-1782的当前最新版1782EMS.109了。后来,我还把BIOS成功升级到了最新版本E1782IMS.11D。
然后,我只尝试着去直接刷E1783IMS.11D, 可未能成功。我还没有去刷MS-1783的EC,因为我不确定刷BIOS和EC的顺序,所以我先试了刷BIOS,没有刷EC。
目前机器可以正常运行Win10,集成显卡INTEL HD 530也可以正常工作,只是GTX980无法安装Nvidia驱动,被识别为Microsoft Basic Display Adapter。
除了通过UEFI的更新BIOS途径,还有其他方法可以强行刷新BIOS么?例如在纯DOS环境下?
还是BIOS芯片已经被刷坏,必须重新换BIOS芯片才能解决此问题?
谢谢您的帮助。
« 最后编辑时间: 八月 03, 2017, 06:02:37 下午 作者 tikoer »
« 回复 #3 于: 八月 07, 2017, 04:37:47 下午 »
1.从您给出的信息判断,您电脑应该是1782,并不是1783.
2.能否提供机器上所有贴纸的照片?先看看能够进一步判断机器的型号。
3.键盘旁边是否有一个GPU按钮?当GPU按钮亮的时候,才能安装NVIDAI 显卡驱动。如果GPU按钮不亮,请按GPU按钮切换到NVIDIA显卡模式,然后安装NVIDIA 显卡驱动。如果按GPU按钮不反应,请至MSI官网下载更新SCM.
谢谢!
tikoer
« 回复 #4 于: 八月 08, 2017, 07:05:44 下午 »
通过官方网站的配置介绍和我的硬件对比后,我的笔记本跟GT72S 6QF风暴英雄版完全吻合。
打开底部面板后,发现GTX980的显卡,并且显卡的散热铜管是3根,而GT72S 6QE的GTX980M是两根。
机器内部的一些贴纸显示,这部笔记本是2016年7月中组装的,这也吻合6QF的发布时间。
还是什么方法可以分辨出6QE和6QF的区别呢?我想最后的办法就是拆掉主板,翻过来看型号,到底是MS1782还是MS1783。
我现在卡在BIOS写保护这里。我试图刷回MS-1783的最新版BIOS,可是AFUWINGUIX64一直给我错误信息, "4 - Error: ROMfile ROMID is not compatible with existing BIOS ROMID“ 或者是"18 - Error: Secure Flash Rom Verify fail."
我在BIOS的高级菜单里没能找到关掉刷BIOS安全检验的选项,请问我怎么可以关闭BIOS的安全检验(BIOS写保护)?
tikoer
« 回复 #5 于: 八月 09, 2017, 07:24:15 下午 »
我还是花费了1个半小时把主板拆下来了。翻过主板仔细一看,原来主板型号就是MS-17821 Ver 2.0!
所以这部机本来就是GT72S 6QE,BIOS版本没有错,只是显卡由原配的GTX980M换成了GTX980。
回到最开始的问题,GTX980显卡驱动安装不上,耳机口插上耳机没声音。
是不是6QE本来就没法支持GTX980?还是这块GTX980有硬件故障?
大师005
  • Full Member
« 回复 #6 于: 八月 10, 2017, 06:59:59 下午 »
这机种无法安装GTX 980的显卡,
使用Intel VGA显卡进行开机再确认看看耳机接口的问题,
另外确认声卡驱动已安装MSI官网上的版本,接上耳机后是否有切换输出的选项呈现在画面上?
