作者 主题: GE62-6QD 1077xcn经常蓝屏求助  (阅读 2082 次)
« 于: 九月 18, 2016, 11:32:28 上午 »
[font='DIN Pro', Arial, Helvetica, 'Microsoft JhengHei', 微軟正黑體, sans-serif]蓝屏一天就三四次。有时候在玩游戏,有时候在打字,还有时候浏览网页都可能突然蓝屏。[/font][/color]
[font='DIN Pro', Arial, Helvetica, 'Microsoft JhengHei', 微軟正黑體, sans-serif]蓝屏代码:[/font][/color]
[font='DIN Pro', Arial, Helvetica, 'Microsoft JhengHei', 微軟正黑體, sans-serif]KERNEL_SECURITY_CHECK_FAILURE (经常出现)[/font][/color]
[font='DIN Pro', Arial, Helvetica, 'Microsoft JhengHei', 微軟正黑體, sans-serif]DPC_WATCHDOG_VIOLATION 【偶尔出现】[/font][/color]
Re: GE62-6QD 1077xcn经常蓝屏求助
« 回复 #1 于: 九月 18, 2016, 11:33:11 上午 »
WIN10的电脑 64位
« 回复 #2 于: 九月 19, 2016, 09:59:01 上午 »
Microsoft (R) Windows Debugger Version 6.8.0004.0 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\GYQ\Desktop\dmp\091816-6531-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path.           *
* Use .symfix to have the debugger choose a symbol path.                   *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by:                                    *
*   using the _NT_SYMBOL_PATH environment variable.                 *
*   using the -y <symbol_path> argument when starting the debugger. *
*   using .sympath and .sympath+                                    *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Kernel Version 10586 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0xfffff803`f6683000 PsLoadedModuleList = 0xfffff803`f6960cd0
Debug session time: Sun Sep 18 19:48:15.193 2016 (GMT+8)
System Uptime: 0 days 2:02:43.015
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 133, {1, 1e00, 0, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : hardware_ram ( PAGE_NOT_ZERO_VISTA )
Followup: MachineOwner
 *** Memory manager detected 57904 instance(s) of page corruption, target is likely to have memory corruption.
« 回复 #3 于: 九月 19, 2016, 10:21:45 上午 »
建议将内存条拔下来用橡皮擦一下金手指的地方再接上
« 回复 #4 于: 九月 19, 2016, 10:23:32 上午 »
另外卸载英伟达显卡驱动,重装微星官网上的显卡驱动
« 回复 #5 于: 九月 19, 2016, 11:01:54 上午 »
显卡驱动已经按照客服的要求,进行了DDU卸载重装。但是问题依然没有解决~
« 回复 #6 于: 九月 19, 2016, 11:03:19 上午 »
再付一个DEBUG
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
